TwinTurbo.NET: Nissan 300ZX forum - I think it's better to actually run them and look for a
jzack
on March 10, 2010 at 6:55 PM
I have found posts on how to check for bad injectors>
posted by BrianTT(Tpa,Fl)
on March 10, 2010 at 07:45 AM
spark (no guessing that way). Pull pack, slip in spare spark plug and ground threaded body, connect pack to car'sharness, crank or start engine and look for a spark....
BrianTT(Tpa,Fl)
07:45:29 03/10/10
swap a coil pack from a working cylinder
Ahmed (Chicago)
08:02:17 03/10/10
coils should ohm around .7 (n/m)
Paulym1111
08:08:26 03/10/10
Where do I check? At the coil or ECU? (n/m)
BrianTT(Tpa,Fl)
08:11:13 03/10/10
check the ohm's from the pins on the coil pack itself..
Paulym1111
09:40:01 03/10/10
Thanks for the info! (n/m)
BrianTT(Tpa,Fl)
09:58:55 03/10/10
I think it's better to actually run them and look for a -
jzack
18:55:44 03/10/10
